These routers are not worth the P+P let alone £40!
- These routers are not worth the P+P let alone £40!
- « Previous
- Next »
Re: These routers are not worth the P+P let alone £40!
26-09-2012 11:48 PM
All I want is a router to work. The ones provided really should! I can't speak for the 582n but my 585v7 is possible the worst thing I have ever used (worse than the HP iPaq running Windows Mobile, that actually did what it said!).
At least you guys don't send the 585 out anymore!
And, yes, we did buy a new router that blew up when plugged in -.- May have to try the 582n since it's £5 despite what I'm hearing here or get a nice netgear if I have to.
Not bashing because everyone else is, my current router is abysmal.
27-09-2012 12:00 AM
28-09-2012 11:53 AM
443 -> 22
80 -> 80
22 -> 22
and set up Dynamic DNS, woop
25-10-2012 9:10 AM
Been with PlusNet for only 2 weeks now, but already decided the router is a piece of junk. I've set up port forwarding twice now, and it works initially then after a bit of time it seems to lose these settings, or becomes "disconnected" with the device and it's MAC address, so it no longer works. Could be after a reboot, it might not be.
So pretty much it's a useless piece of plastic for me.
Anyone recommend a good replacement? Can I get a refund on the P&P for this doorstop?:)
25-10-2012 5:29 PM
25-10-2012 7:19 PM
Don't get me started on the GUI interface - but we shouldn't have to resort to the busybox command line to get it working how we want.
PS: Other than the router I am really happy with the Plusnet service and support so far - Top notch, well done fellas (and presumably gals, though I have yet to come across one ::))
26-10-2012 7:42 AM
Quote from: tijara33 I've returned 2 of the Technicolor so called fibre routers. I'm now using a TP Link WR1043ND. It's much faster & there is no speed loss wirelessly 3 rooms away. Highly recommended.
Cheers.
I've got a replacement coming my way, but I won't use it - I've ordered a BT home hub 3 off ebay, and see if that does the job. I'll keep the TP Link one in mind.. I've got a TP link Gigabit switch, I've been happy with their devices in the past.
31-10-2012 8:46 PM
I can't believe someone said this thing is "significantly better" than a DGN2200, seriously I nearly fell off my chair and my ribs are still hurting
There's probably bluetooth devices out there with better range than these things
New customers, do yourselves a favour, there's much better uses for that fiver p&p
01-11-2012 12:20 AM
Quote from: Pagmalupitan How can the wireless possibly be any good with just a 3ish inch track on the pcb acting as an aerial
Dunno but it provides the same signal strength as my netgear dg834v3 from ground level to top floor in my 3 storey house. It isn't the fastest router I have but it is extremely stable on fault ridden bt infrastructure making it a welcome alternative to my faster but inclined to instability bipac billion 5200g. It also doesn't lock me out every couple of days like my thompson 585 does because I prefer to use my own personal settings rather than the factory standard ones.
Different strokes for different folks, I guess
As far as the OPs grievance over the 585 goes, after 2 or maybe 3 replacements, all of which crashed with alternative settings, I just gave up and refused to let plus.net send out any more
The routers supplied by plus.net are a basic minimum really. Good enough to allow customers to access the service out-of-the-box but not much more really. Neither do they need to be, in all honesty. And, still in all honesty, whatever make/model they provide, there will always be someone who isn't satisfied. If you think that there is a better option out there for you (whoever you are) then by all means go out there and buy it - just don't expect me to agree to a price hike on my service so that your ISP will provide it to you for the price of a postage stamp!!
01-11-2012 9:57 PM
Quote from: CliffTopp ... but it is extremely stable on fault ridden bt infrastructure making it a welcome alternative to my faster but inclined to instability bipac billion 5200g.
To be fair the modem side did seem rock solid
It's a shame there's no official (via the gui) way to enable a bridge/modem-only type mode. I did get it working in some sort of modem-only mode via telnet commands (there's a few brief instructions around the forum) in conjunction with an old cable router I have laying around. So that's an option open to people suffering poor wireless
01-11-2012 11:18 PM
The disadvantage is that the antenna is horizontal and there are likely to be directional effects. I did see someone else posting about rotating the modem/router and getting an improved signal. Although that can work, personally I don't thing that is ideal.
01-11-2012 11:34 PM
01-11-2012 11:41 PM
What's the orientation of the 'antenna' track on the PCB? If the router is positioned so that this is vertical does the wi-fi improve?
02-11-2012 2:14 AM
Quote from: w23 What's the orientation of the 'antenna' track on the PCB? If the router is positioned so that this is vertical does the wi-fi improve?
I tried standing mine on its side, the connection speed upstairs still fluctuated constantly.
04-11-2012 10:05 PM
Quote from: Anotherone ...I do feel I should point out that a printed track antenna is a perfectly valid way of transmitting signals at the microwave frequencies that wi-fi operates at. This isn't just any old length and width of track, it is carefully calculated for the frequency of operation.
That may well be true and unavoidable in certain devices (phones etc.) but it's a router! Why not just add an external aerial or two (or three) like other manufacturers???
Just cost cutting at it's worst
Maybe someone could try adding an external aerial(s), there are two SMD aerial connectors on the board (i don't know the type - the same as those found on latop wifi cards etc.) just waiting to have something plugged in to them
- « Previous
- Next »
