The Great Conspiracy Theorist....
- The Great Conspiracy Theorist....
- « Previous
- Next »
Re: The Great Conspiracy Theorist....
02-09-2014 10:39 PM
02-09-2014 10:47 PM
Quote from: jelv For Windows PCs I suggest you install http://www.softperfect.com/products/networx/ to monitor usage (free download at the bottom the page).
Have you done this? It's usage report has a tab to show you how much is used per application.
02-09-2014 11:10 PM
Edit: Seems like I have used Anti-Malware before - it tells me my "Free Trial" has expired!
03-09-2014 7:34 AM
By default it tries to install the pro (or similar) version which has enhanced functionality for a while then expires. Make sure you tick the right box when installing
03-09-2014 8:16 AM
03-09-2014 9:05 AM
Quote from: jelv There's a well documented issue with iTunes gobbling huge amounts of data usage after a recent update. See https://discussions.apple.com/message/23710128
Unchecking Internet Explorer bookmark syncing in iCloud may solve your issue.
Having a suitable Software Firewall that controls the Outgoing can also be beneficial BUT you need to understand how to use it and customise it.
03-09-2014 6:25 PM
*Mumbles incoherently*
*Looks down at feet*
I think I might have found it.
Going through Task Manager later on and looking at "Processes" I saw a programme operating that shouldn't have been.
I suspect that when I updated it last it pinned itself to the "Run at Start up" - so did so when we switched on yesterday - unbeknownst to all.
Always check the label folks!
Thanks for the suggestions - Networx is useful!
03-09-2014 7:55 PM
03-09-2014 8:02 PM
Don't forget to eat humble pie to your wife for accusing her "non Apple product" ......
Care to share what the offending program was (just for future reference) - don't worry if it is something you'd rather not share
Hopefully that will be the end of your issues
29-10-2014 12:24 AM
Turns out to be academic - as we all seem to be using more data now anyway. Tried to keep a lid on it, but generally it's just a sign of the times.
- « Previous
- Next »
