The BT speedtester is still broken
- The BT speedtester is still broken
Re: The BT speedtester is still broken
26-08-2008 5:09 PM
26-08-2008 5:10 PM
26-08-2008 6:00 PM
26-08-2008 8:36 PM
26-08-2008 8:58 PM
SW.
3Mb FTTC
27-08-2008 8:38 AM
Quote from: axisofevil You mean the BT speedtester worked for you?
It does work - eventually, but it's a pain having to keep trying
Why doesn't BT sort this problem out?
30-08-2008 11:43 PM
I have Xp Pro and always used latest updates for everything. In Aug 2007 suddenly I could no longer run the test in FF2 (ok in IE) and got the exception that was mentioned at the beginning of this thread. After enquiring on many sites I eventually solved the problem by uninstalling the lastest Java JRE, clearing out any ref to Java in the registry and reinstalling build 1.5.0_08-b03 (otherwise known as JRE 5.0 update 8). Certainly any build 6 and above failed. I have not 'crept' forward beyond update 8, but if I remember correctly, update 15, for version 5 (the last update before version 6) failed.
If you want an older version of Java try http://java.sun.com/products/archive/ ;
This situation is appalling considering BT's speedtester pages say that it runs in FF and that you should have the latest version of JRE. I thought that the problem might be solved when FF3 came out, but it wasn't, and because of other problems using FF3 (see below) I returned to FF2 and old JRE.
I have also returned from FF3.01 to 2.0.0.16 as I found that the format of the Orange webmail pages did not display properly. Again this is not a problem with IE. When I complained to Orange, they just respond that they do not support FF. In addition Orange have 'updated' their webmail pages (mid Aug 08) and the display in IE or FF is a complete mess with similar pages (eg Inbox Spam etc) not displaying in a similar manner with Icons missing and text/text boxes 'jumping' about the screen!
31-08-2008 9:42 AM
My wife Uses Weight Watchers web site, that is horrible, complained to them that it dosnt work correctly with FF3, they said we have only tested it with FF1
31-08-2008 11:26 AM
31-08-2008 1:11 PM
https://addons.mozilla.org/en-US/firefox/search?q=IE+tab+&cat=all
31-08-2008 3:18 PM
Each time I try, it tells me that my telephone number is invalid and can't be authenticated.
I've tried with IE, Opera and Firefox. They're all the same.
Keith
03-09-2008 10:06 AM
BT test did eventually run, then stalled at 96% and froze at that
03-09-2008 12:19 PM
03-09-2008 3:49 PM
03-09-2008 7:29 PM
Results Image not loaded
Test1 comprises of Best Effort Test: -provides background information.
Your DSL connection rate: 8096 kbps(DOWN-STREAM), 448 kbps(UP-STREAM)
IP profile for your line is - 7000 kbps
Actual IP throughput achieved during the test was - 5757 kbps
