Tester TG582n same firmware but incompatible configs?
- Tester TG582n same firmware but incompatible confi...
30-05-2013 3:11 PM
I was sent a tester router to rule out an issue with my current TG582n, my current router has 8.4.4.J and the tester I got also had the same firmware. So I uploaded a backup of my current routers setup to it and it locked up.
It wouldn't accept any lan connections and couldn't be pinged. Hardware differences between batches affecting the config?
I did a factory reset and uploaded it again with the same result.
Note I never changed the IP address of the router and use the default 192.168.1.X for my pc's and laptop same as the router came with
edit: forgot to say yes it was After the initial 15 mins when it does its remote setup when I changed the config via the backup
FTTP 500 regrade from Tues 28th November
Message 1 of 2
(577 Views)
1 REPLY 1
Re: Tester TG582n same firmware but incompatible configs?
30-05-2013 4:20 PM
Message 2 of 2
(272 Views)
