Terrible connection
TerryCTR
Terrible connection
Tonight my connection is horrendous.
0.22 Mbps down, 0.05 up and 80 ms ping is not quite the 20 meg I should be getting
Can someone have a look at it and sort
Terry
TerryCTR
Re: Terrible connection
Bump for Monday morning
ScottStorey
Hi TerryCTR,
Sorry to see you are having problems with your speed.
I've just run a check on your line and it's showing you should be getting around 21Mbps and that there are no problems on the line.
Are you getting these slow speeds on a wired or wireless connection?
If you are on a wireless connection could you try a speed test on a wired connection please.
Bright
Or you might just be suffering from this, along with many other customers:
http://community.plus.net/forum/index.php/topic,111170.0/
TerryCTR
Over the weekend it kept going back to normal then running poorly so its not a wireless issue.......its the line
I should mention that it was tested on a wired line from the master socket incase you say it could be the wireless
TerryCTR
Still running like link:censored.
Right now it made an impressive 5 meg down!
adie:red avoidance of swear filter removed as per link:rules
Plusnet Staff
Plusnet Staff
Fixes: 5
The times you have posted appear to be during peak times.
Do you still experience problems during the day too?
Chris Pettitt
Cloud Environments Engineer
TerryCTR
I couldn't tell you, I'm at work during the week and come the weekend I take it that it would be closer to peak?
It's running ok right now
TerryCTR
I am also connected to a ptn-ag03 line so it's not the issue linked above
englishrick
Its the usual peak time slow down....Mine has gone down to about 30mb from 65mb... and no doubt will drop further....
TerryCTR
Apparently I pay so that won't happen  Roll eyes
I just saw the reply on my ticket saying I will be charged if an engineer is called out. Each time there is a problem, that's the reply I get and each time so far it's not been the anything to do with internal.
If it comes to it I will just cancel as I'm not gaming anymore anyway and sky broadband is cheaper and will do for surfing the web
Plusnet Staff
Plusnet Staff
Fixes: 5
The potential £60 charge is only applicable if the fault is found to be caused by anything internal as you have stated. We have to put this across to you before we go ahead with the visit just in case it is an internal issue.
I can see that your fault is in the hands of our Faults Team who have raised the fault to our suppliers for further investigation. If you aren't happy to accept the potential charges then we wouldn't be able to send you out an engineer I'm afraid.
Chris Pettitt
TerryCTR
Yes i sure have.
No problem if it comes to that I will just cancel then as its not an issue my end going on everyone else's peak time problems of late.
