Temporary loss of connectivity.
- Temporary loss of connectivity.
- « Previous
- Next »
Re: Temporary loss of connectivity.
18-03-2015 3:15 PM
So am I
I do not think we would disagree that "Normal" VP congestion does not tend to show as pervasive packet loss as is seen by Mook's BQM. I was thinking about the PlusNet's OWN exchange monitoring graphs (rather than the BT VP status) - see http://community.plus.net/exchange-information/ - though the graphs are not there at present.
Do they show a similar all day issue as per Mook's BQM across the users connected to that exchange?
If they exist and they are the same then we can "dismiss" this as VP congestion, if they do not then may be some other issue should be considered. Though there is high packet loss, looking at the gaps where it is lower, there does not appear to be high latency - just does not feel right to me.
Kevin
18-03-2015 3:49 PM
What I am finding odd is that the Minimum Latency plots seem to "flat-line" at around 40ms.
Would the type of traffic have any bearing on this?
I certainly agree with Kevin's fundamental thought, that this doesn't look just like straight forward VP congestion and warrants closer examination.
21-03-2015 8:33 AM
21-03-2015 8:39 AM
21-03-2015 8:51 AM
21-03-2015 5:01 PM
22-03-2015 8:33 PM
Quote from: Mook It is, and totally defeats the purpose of my load balancing, and what makes it even worse is that I'm paying £34 pm for it!
Mook,
Indeed the offer was to move the bad link to the same one (blue) as the good line. Would you know (can CRT advise) if there are three or more VPs on your exchange? What are they like? Are they better than the present really bad one?
CRT see also - http://community.plus.net/forum/index.php/topic,137901.msg1183617.html#new
Kevin
24-03-2015 9:00 AM
- « Previous
- Next »
