Technicolour TG852n
- Re: Technicolour TG852n
Technicolour TG852n
26-01-2016 9:29 PM
Hi.
Please can someone let me know if the Technicolour TG852n router can be used for broadband ADSL (not fibre). If so, are there any changes that I need to make?
Many Thanks.
Many Thanks.
Message 1 of 9
(1,371 Views)
8 REPLIES 8
26-01-2016 9:30 PM
you need to reflash the firmware
Message 2 of 9
(860 Views)
26-01-2016 9:50 PM
I have an ex-FTTC 582n which works on ADSL just by changing the WAN settings.
Message 3 of 9
(860 Views)
26-01-2016 10:38 PM
Was this a PLUSNET 582N issued to you, if second hand it may be tied to another ISP .or may be linked to another plusnet account.
What firmware does it have on it now?
Message 4 of 9
(860 Views)
27-01-2016 11:18 AM
Hi.
Thanks for the responses.
it is Plusnet issued, but it was for my own fibre broadband. I have set up broadband ADSL for my mother and thought I could use the 852n for that. So maybe it has already been linked with my fibre account. Don't know what firmware it has as not used for about a year, but was used when my fibre was set up. I now use a HH3, am going to try that as should work with ADSL, will probably get a HH4 of ebay.
Thanks.
Thanks.
Message 5 of 9
(860 Views)
27-01-2016 12:08 PM
That's similar to mine. My 582N was supplied for another customer's Plusnet FTTC connection, but unused since they have their own equipment. The router GUI says Plusnet and FTTC. All I had to do to get it working on my home ADSL was to change the WAN mode and put my own credentials in.
Message 6 of 9
(860 Views)
27-01-2016 12:18 PM
Yes its worth trying - the setup info is here:
The password would have to be your mothers.
If it works ok great , at that point you could flash it with the proper adsl firmware or ask Plusnet to "push" it onto the router.
EDIT inserted in quotes it seems to work
Quote http://www.plus.net/support/broadband/hardware/broadband-connection-settings.shtml
Message 7 of 9
(860 Views)
27-01-2016 1:08 PM
Quote from: Oldjim you need to reflash the firmware
How do I do this?? Sorry for being a novice ha ha.
Quote from: cedlor Yes its worth trying - the setup info is here:
Hi. this link isn't working?
Many Thanks.
Message 8 of 9
(860 Views)
27-01-2016 2:00 PM
Plusnet's guides for the 582N are here http://www.plus.net/support/broadband/hardware/index.shtml?supporta=setupguides but I think that probably won't cover converting an FTTC router to ADSL. I found it pretty self explanatory on the user interface when I did ours, and I didn't change the firmware. The only jiggery pokery was getting the fourth Ethernet to work.
Message 9 of 9
(860 Views)
