Technicolour Router will not speak to Sky On Demand Wireless Coonector
- Re: Technicolour Router will not speak to Sky On D...
08-11-2013 4:56 PM
Sky have run out of ideas - you can tell that when the line suddenly goes dead. For what it is worth, everything works fine if I use a wired connection, but that is not a practical solution for me due to the position of the router in relation to the wireless connector.
This may be a forlorn hope, but has anyone managed to get connection between these two bits of equipment?
Re: Technicolour Router will not speak to Sky On Demand Wireless Coonector
08-11-2013 5:02 PM
See if you can find your network then.
08-11-2013 5:03 PM
08-11-2013 5:25 PM
08-11-2013 5:47 PM
Andy H - the link you sent doesn't work. Can you check please
Oldjim - I think you may be right. I have been through all of those instructions and many more dreamt up by Sky Advisors without any success.
tijara33 - it may be, but I have been using it for over a year now without any other problems
08-11-2013 6:36 PM
A lot of people resolved their issues this way.
08-11-2013 7:11 PM
08-11-2013 7:45 PM
Username: admin
Password: sky
You need to connect your ethernet cable on your PC/Laptop into the Sky Wireless Connector (if you aren't already doing this)
There's a bit of a guide here http://www.chrisnharvey.com/blog/2013/06/hacking-the-sky-wireless-connector
11-11-2013 10:36 AM
Many thanks AndyH, I got there in the end.
11-11-2013 10:40 AM
For some reason, a lot of users have the problem where the connector doesn't find the wireless network. But if you set it up manually as below, then it works fine. I don't think Sky would tell you about accessing the config page for the wireless adapter - even though that is the only way some people can get it to work!
12-11-2013 10:54 PM
12-11-2013 11:07 PM
