Technicolor router features
- Re: Technicolor router features
23-03-2014 10:33 PM
I believe some net monitoring software can exchange this sort of info with some routers, but I'm not sure what feature(s) I should be looking for.
Any enlightenment appreciated.. 🙂
23-03-2014 10:48 PM
Technicolor TG582n User Guide
Printer sharing TG582n
CLI REFERENCE GUIDE R10.2 MediaAccess TG582n
Also check out Telnet Commands for a Thomson / Technicolor Router
Hope these help
24-03-2014 10:47 AM
24-03-2014 6:44 PM
Home Network > Access Control
24-03-2014 6:48 PM
There isn't a heading Access Control
24-03-2014 8:06 PM
Device Access Scheduler
This feature allows you to configure the times that specific devices can access the Internet through your Technicolor Gateway.
This can be used as a form of parental control.
Select device: There is a drop down here
Any device that show in the format Unknown-XX-XX-XX-XX-XX-XX are your devices that the Technicolor Gateway can not find the full name for, you can configure these manually here.
26-03-2014 1:51 PM
I'm sure it's in there somewhere...
26-03-2014 2:52 PM
26-03-2014 3:17 PM
http://products.plus-payh.co.uk/firmware/
26-03-2014 6:18 PM
26-03-2014 7:55 PM
Make sure you got a plentyful supply of ear plugs / defenders
Let me know if you successfully manage to get this set up, as I have not tried it yet due to other issue(s) known in another thread
26-03-2014 8:37 PM
27-03-2014 3:07 PM
IE: Going to make a brew
If not then no it should not ask you to repeatedly log in
Try a basic reset of the router (see if that helps)
