Technicolor router drops connection or doesn't appear at all
- Technicolor router drops connection or doesn't app...
01-09-2013 2:03 PM
Plusnet changed me to the supposedly more powerful technicolor router. My iMac is connected by cable and works well. My iPad not so well. In the room underneath the router I get a full signal but listening to Internet radio it drops me out. In other parts of the house I get signals varying from nothing to 1bar to 2bar. The signals fluctuate by the second. My wifi enable HDD recorder does not register plusnet wireless at all although lots of o ther signals appear - mostly BT.
I have tried a range extender - it worked for a bit then was intermittent then wouldn't connect at all.
I've spent days trying to sort this out - at this rate Plusnet owe me. All they can offer is to change channel. This I have done innumerable times. I've looked at moving the router but suitable places do not have a power point and phone connection together.
Sky if offering me a slightly cheaper deal but the only thing Plusnet seems to have going for it is that you can get through to someone. But they keep saying they are not trained to deal with Apple products which is disgraceful.
I live in West London in a mid-terraced house. Any suggestions anyone?
Message 1 of 4
(2,767 Views)
3 REPLIES 3
Re: Technicolor router drops connection or doesn't appear at all
01-09-2013 3:34 PM
You can try changing various wifi settings with telnet: http://npr.me.uk/telnet.html#tweaks
Maybe also:
wireless radio sgi=enabled cdd=enabled stbc=enabled
Maybe also:
pwr wlan-pwr-options single-rxchain=disabled
Message 2 of 4
(908 Views)
02-09-2013 4:09 PM
Quote But they keep saying they are not trained to deal with Apple products which is disgraceful.
I'm sorry if you've been told that, where as it's right that we don't provide support for issues relating to any type of device be it an Apple one or otherwise we aim to be able to support customers through issues with our service which does sometimes involve a basic knowledge of non-windows based operating systems.
I know you've tried changing channel but have you been able to try running
<a href="http://www.metageek.net/products/inssider-for-mac//">inSSIDer</a> to see if that indicates any issues in the local wireless environment?
Message 3 of 4
(908 Views)
02-09-2013 4:50 PM
Hi Ras4814,
Same TG582n problem as You, 1 to 2 Mbps detected.
Had to move router for PCI WiFi card in PC to pickup TG582n.
Look at my thread (Router TG582n and signal level).
There is a link to a new Firmware for TG582n that
helps with the Wi fi range Problem.
Did a couple of Telnet Commands to router that helped, try
new Firmware first.
I can't Upload Firmware with the tool provided because I
am running (Windows and the Upload tool only
does up to Win 7.
You don't need to do it yourself, I think his Name is (Matt) a
member of staff.
You give him your Routers Code Name and he pushes the new
Firmware into you Router.
look on PlusNet site (192.168.1.254) to check your router Firmware.
My Firmware is 8.4.4.J and I will ask (Matt) to update my Router,
just need to find his Thread.
BF.
Message 4 of 4
(908 Views)
