Technicolor compatible unmanaged ethernet switch
nitrams69
Hi everyone my first post and i'm due to be connected to fttc on Tuesday. I received my router today only to notice i wont have enough ethernet ports
What switches are compatible with technicolor tg582n i would like something that's hopefully future proofed.Do i need to go for 100mb or
higher.
Thanks in advance.
Fixes: 10
Re: Technicolor compatible unmanaged ethernet switch
Any unmanaged ethernet switch will be compatible. If you will be doing large transfers between devices internally a gigabit switch may be worth the extra cost.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
This got some good reviews recently (nice power saving features too): http://www.amazon.co.uk/GS-105B-Gigabit-Unmanaged-Desktop-Switch/dp/B001HLT84K/ref=pd_sim_computers_...
Call me 'w23'
nitrams69
Thanks jelv and w23. I have ordered the zylex 5 port you linked. Roll on tuesday hoping for a painless install.  Smiley
Fixes: 100
Make sure you have enough ethernet cables handy.
Installing an unmanaged switch is about as easy as it gets Smiley
Customer and Forum Moderator.
@nitrams69, did you get the V1 or V2?  How is it doing (seriously thinking of getting one myself)?
Call me 'w23'
jtonline
I bought a Newlink NLHUB-588A 8 Port Gigabit Switch.  I got some flat cat6 patch cables too which fit nicely into some thin trunking above the skirting board Smiley
http://cpc.farnell.com/newlink/nlhub-588a/switch-network-gigabit-8-port/dp/CS21214?Ntt=CS21214
nitrams69
Got the version 1 and iv'e had no issues at all just plug in and go.Not sure what the v2 benefit would be.
Quote from: nitrams69
Cheers for that.  Smiley  I actually think the V1 might be the better of the two, that's what I'd be looking for.
Call me 'w23'
