Technicolor compatible unmanaged ethernet switch
- Re: Technicolor compatible unmanaged ethernet swit...
12-10-2012 8:35 PM
Hi everyone my first post and i'm due to be connected to fttc on Tuesday. I received my router today only to notice i wont have enough ethernet ports
What switches are compatible with technicolor tg582n i would like something that's hopefully future proofed.Do i need to go for 100mb or
higher.
Thanks in advance.
higher.
Thanks in advance.
Message 1 of 9
(1,825 Views)
8 REPLIES 8
Re: Technicolor compatible unmanaged ethernet switch
12-10-2012 8:41 PM
Any unmanaged ethernet switch will be compatible. If you will be doing large transfers between devices internally a gigabit switch may be worth the extra cost.
Message 2 of 9
(672 Views)
12-10-2012 9:37 PM
This got some good reviews recently (nice power saving features too): http://www.amazon.co.uk/GS-105B-Gigabit-Unmanaged-Desktop-Switch/dp/B001HLT84K/ref=pd_sim_computers_...
Call me 'w23'
Message 3 of 9
(672 Views)
13-10-2012 1:03 PM
Thanks jelv and w23. I have ordered the zylex 5 port you linked. Roll on tuesday hoping for a painless install.
Message 4 of 9
(672 Views)
13-10-2012 1:09 PM
Make sure you have enough ethernet cables handy.
Installing an unmanaged switch is about as easy as it gets
Message 5 of 9
(672 Views)
01-11-2012 5:25 PM
@nitrams69, did you get the V1 or V2? How is it doing (seriously thinking of getting one myself)?
Call me 'w23'
Message 6 of 9
(672 Views)
01-11-2012 6:31 PM
I bought a Newlink NLHUB-588A 8 Port Gigabit Switch. I got some flat cat6 patch cables too which fit nicely into some thin trunking above the skirting board
http://cpc.farnell.com/newlink/nlhub-588a/switch-network-gigabit-8-port/dp/CS21214?Ntt=CS21214
Message 7 of 9
(671 Views)
01-11-2012 8:01 PM
Got the version 1 and iv'e had no issues at all just plug in and go.Not sure what the v2 benefit would be.
Message 8 of 9
(671 Views)
01-11-2012 8:10 PM
Quote from: nitrams69 Got the version 1 and iv'e had no issues at all just plug in and go.
Cheers for that. I actually think the V1 might be the better of the two, that's what I'd be looking for.
Call me 'w23'
Message 9 of 9
(671 Views)
