Technicolor TG789vn v3 MediaAccess Gateway
baz21
Technicolor TG789vn v3 Media Access Gateway.
Can I use a TG789vnm v3 Router and how would I set it up to Plusnet, any help appreciated.
Baz21
1 REPLY
Fixes: 50
Re: Technicolor TG789vn v3 MediaAccess Gateway
It should work fine. The on-line manual seems a bit lacking in detail though.
You will need to configure it's Broadband (DSL) connection with you PlsuNet account details.
The generic connection guide is here http://www.plus.net/support/broadband/hardware/broadband-connection-settings.shtml
Hope that helps
