Technicolor TG789vn v3 MediaAccess Gateway
- Technicolor TG789vn v3 MediaAccess Gateway
21-08-2015 4:24 PM
Technicolor TG789vn v3 Media Access Gateway.
Can I use a TG789vnm v3 Router and how would I set it up to Plusnet, any help appreciated.
Baz21
Message 1 of 2
(856 Views)
1 REPLY 1
Re: Technicolor TG789vn v3 MediaAccess Gateway
21-08-2015 5:02 PM
It should work fine. The on-line manual seems a bit lacking in detail though.
You will need to configure it's Broadband (DSL) connection with you PlsuNet account details.
The generic connection guide is here http://www.plus.net/support/broadband/hardware/broadband-connection-settings.shtml
Hope that helps
Hope that helps
Message 2 of 2
(614 Views)
