Technicolor TG582n
bluenose
Technicolor TG582n
Just switched on the above router - what is the WPS button for?
Exdee
Re: Technicolor TG582n
It's there if you want to connect a device to your router without having to input the wireless security key. You just scan for the network on your device and click Connect. Then when prompted press the WPS button on your router and you will be connected.
bluenose
Thanks Exdee, I'll leave it switched off then (the wps button that is!)...
regards
