Technicolor TG582n
- Re: Technicolor TG582n
Technicolor TG582n
27-12-2013 2:44 PM
hi
I tried to update my router to the lastest firmware a few times over the last few days it will not let us
any chance of sending one down to it from your end
has over the last few days my net speed has got slower so a upgrade might help when I was with sky sky did them automaticly
thanks
conrad
thanks
conrad
Message 1 of 8
(1,148 Views)
7 REPLIES 7
27-12-2013 2:51 PM
Hi, its unlikely to be the router causing your slowness. I've had a look at your account and you are definitely slower than you use to be!
Your line seems to be fluctuating between about 9Mbps and 3.8Mbps which it is currently at and is the slowest it's been.
I suspect the disconnections we are seeing on your line are causing the BT DLM to lower your speeds to make your line more stable:
Is your phone line nice and quiet?
Kelly Dorset
Ex-Broadband Service Manager
Message 2 of 8
(518 Views)
27-12-2013 3:04 PM
hi
kelly
the phone extension it was always on so i had to move to a diffrent socket which where it is for now and it is nearer to master socket then it has ever been
i thought it was the bt thing slowing our line down should that come off in a few days when it is been on 16 hours now with no down turn
or do you need to reset your end for it to find its own speed again
hi kelly the phone like it has always been
many thanks
conrad
kelly
many thanks
conrad
Message 3 of 8
(518 Views)
27-12-2013 3:14 PM
Are you using microfilters on all your phones? Also, do you have a Sky box, and is that filtered too?
Kelly Dorset
Message 4 of 8
(518 Views)
27-12-2013 3:17 PM
hi
sky box not connected has not been for years m8
no microfilters on other phone connections
should they have
thanks
Conrad
should they have
thanks
Conrad
Message 5 of 8
(518 Views)
27-12-2013 3:20 PM
Quote from: cbate no microfilters on other phone connections
should they have
Only if they have something plugged in to them - telephone, fax machine, etc.
Message 6 of 8
(518 Views)
27-12-2013 3:41 PM
ok all extensions have been checked and all have a filter fitted
conrad
conrad
Message 7 of 8
(518 Views)
27-12-2013 3:46 PM
OK. It's worth raising a fault with us at http://faults.plus.net so we can investigate further.
Kelly Dorset
Message 8 of 8
(518 Views)
