Technicolor TG582n wireless and wired
lib319
Can this router be used to connect wireless devices like laptops at the same time as supporting a wired connection to a PC?  The documentation from Plusnet says no but is that strictly correct?
Fixes: 60
Re: Technicolor TG582n wireless and wired
yes it can - what documentation is that as either it is wrong or you are misreading it
Fixes: 16
What isn't recommended is to have a wifi & wired connection to the SAME device  Smiley
lib319
Quote from: Hairy
Thanks for that guys.  I'm guessing that's why the manual says to use either or.  They must be assuming its for 1 device.
Cheers
