Technicolor TG582n vs Homehub 4
- Technicolor TG582n vs Homehub 4
20-05-2015 12:37 PM
Read the posts on "how to" use the HH but just wondered if it is any better that the TN? Is there any point in switching or should I just bin the HHubs (have 2 of them)?
Message 1 of 2
(665 Views)
1 REPLY 1
Re: Technicolor TG582n vs Homehub 4
20-05-2015 1:29 PM
The Technicolor is more configurable although any advanced settings need to be done via telnet. The HH4 is generally regarded to have a stronger wireless.
So they both have their strengths and weaknesses, you really need to test each one to determine which suits your needs best.
Before you bin any, remember you can always use a second router to extend the wifi to another part of the house if need be.
Message 2 of 2
(375 Views)
