Technicolor TG582n router firmware update required
- Re: Technicolor TG582n router firmware update requ...
20-01-2015 7:46 PM
Re: Technicolor 895gn router firmware update required
20-01-2015 8:49 PM
Please check the router type as that isn't one I recognise as being supplied by Plusnet
21-01-2015 9:17 AM
21-01-2015 2:14 PM
Re: Technicolor TG582n router firmware update required
21-01-2015 2:20 PM
21-01-2015 5:21 PM
21-01-2015 5:46 PM
TG582n with 8.C.M.0
Anytime during the day is fine.
Many thanks
21-01-2015 5:47 PM
22-01-2015 9:13 AM
22-01-2015 11:10 AM
This should help the upload speed be in its normal speed
22-01-2015 12:11 PM
20-03-2015 7:29 AM
I'm looking for a way of applying time-based access restrictions, ideally on a per-device basis.
21-03-2015 7:38 AM
Welcome to the forums.
I cannot give you chapter and verse on 10.2.2.B features, but the headlines are improved xDSL stability (I'm on 248 days) and (as you've mentioned it) hour by hour access restrictions per device.
I'm sure there are other things too.
21-03-2015 7:56 AM
My only concern is knowing exactly which one to use. I currently have 8.4.4.J which according to the page below is the latest for my TG582n router, unless of course I can use the TG582n-PS firmware.
http://products.plus-payh.co.uk/firmware/
21-03-2015 8:13 AM
