Technicolor TG582n "Interleaved" (ADSL)
tonypart
I have had the interleaving turned off on my ADSL line all, indications ping, sync, no FEC errors etc. indicate it is off.
However my TG582n router insists it is on.
I am using verion 10.2.2.B but also had the problem with 8.4.4.J.
Is this just a reporting error with no consequence?
Is it a fault?
Do all TG582ns do this?
Will it cause problems e.g. conflict with the DLM?
Has anyone any ideas?
TonyP
SoFarSoGood
Re: Technicolor TG582n "Interleaved" (ADSL)
Hi Tony
My TG582n does the same.
I believe if FEC errors are shown 0/0, fastpath is on.
Fixes: 69
Yes, it's been mentioned before that the TG582ns don't show a correct interleaving status, it shouldn't cause any issues though.
 Adam Walker
tonypart
OK thanks guys
Every thing seems to work OK,
Just another debit against what could be a really good router if wi-fi was better
TonyP
