Technicolor TG582n - how to change stuff?
- Technicolor TG582n - how to change stuff?
04-04-2012 3:57 PM
Just got my replacement router through and would like to change the LAN IP and the SSID/WiFi Key to what they where on the old router!
When trying to change the SSID I click apply and the screen goes white ... thats it???
Relogging in shows that the device has completely ignored my changes?
Any advice appreciated!
Message 1 of 9
(4,786 Views)
8 REPLIES 8
Re: Technicolor TG582n - how to change stuff?
04-04-2012 4:00 PM
Are you doing this wired or wireless?
Message 2 of 9
(1,046 Views)
04-04-2012 4:01 PM
Can you confirm what browser you are using?
if you are using IE, have you tried IE compatibility mode?
Additionally, have you tried an alternate browser?
Message 3 of 9
(1,046 Views)
04-04-2012 4:03 PM
Wired: Tried FF/IE - just ignores me
Message 4 of 9
(1,046 Views)
04-04-2012 4:05 PM
The op said these werent locked down routers - cant even see how to set dhcp
lease ranges?
Is there a secret to get into the full interface - looks seriously limited to me!
Its ok - Just found that one .... odd about the SSID though?
lease ranges?
Message 5 of 9
(1,046 Views)
04-04-2012 4:17 PM
HI cpcnw,
I've just tested one here and it works fine for me. Have you tried changing just the SSID rather than multiple things at once. If so, then PM me the SSID you're using and I'll try it on ours.
Jojo
Jojo
Message 6 of 9
(1,046 Views)
04-04-2012 4:18 PM
Yep, all my laptops etc are setup to connect to 'morpheus' [sad I know!]
Also, how the hell do you remove the default dhcp lease pools?
Message 7 of 9
(1,046 Views)
04-04-2012 5:26 PM
So weird about the SSID.
For the DHCP go to Home network>Interfaces>Local Network untick 'enable DHCP' then make your changes then re-enable then apply.
Message 8 of 9
(1,046 Views)
04-04-2012 5:54 PM
You bet!
Now it ignores my dhcp changes too !!!
And ... how to get rid of LAN_VIRT
Message 9 of 9
(1,046 Views)
