Technicolor TG582n gateway problem
- Technicolor TG582n gateway problem
30-06-2018 1:15 PM
I have a weird problem. My router is showing no internet connection as it cannot connect to the gateway (195.196.130.252) which when checked with Whois the ip seems to be assigned to a company in Sweden. However here is the weird bit the internet is working perfectly fine from every device connected by either cable or WiFi.
i have reset the router but still get the same issue with the same IP address. How do I fix this issue.
Mark
Re: Technicolor TG582n gateway problem
30-06-2018 2:25 PM
30-06-2018 3:07 PM
Ok but what’s the point of the router check if it always fails like that? How can the consumer know what’s wrong if there is a genuine fault?
30-06-2018 3:46 PM
The feature is one of the vendor's, not ours, and we're no longer actively developing the device so is unlikely we'll be removing it any time soon.
Apologies for any confusion it's caused.
