Technicolor TG582n does not show all devices
rsethi
Hi All
When I click on Home network on my router, some devices are not displayed. There are 3 devices connected using ethernet but only 2 are displayed. Though the 3rd device works fine and I can access it from my laptop or mobile so it is surely connected and working but the router does not display that.
As a result of this, I am not able to do port forwarding onto this device.
can someone please help me.
Regards
Re: Technicolor TG582n does not show all devices
Hi rsethi,
Have you tried a reboot of both your router and the device in question?
rsethi
hello
Yes I have tried to reboot both the devices. The list on the router is pretty erratic. It sometimes does not display all items but sometimes it does.
Regards
Fixes: 5
Are the devices on a static IP. If so ensure they are outside the routers DHCP pool.
