Technicolor TG582n disable remote access
- Technicolor TG582n disable remote access
03-03-2015 12:39 AM
Hi all,
I have a Technicolor TG582n router, I think at some point I enabled remote http access so that I could access the router web interface from the internet. I would like to disable it now, as I'd like to put something else on port 80 - cannot seem find how to do that. Would someone point me to the right direction?
thanks,
thanks,
2 REPLIES 2
Re: Technicolor TG582n disable remote access
03-03-2015 9:43 AM
The following telnet commands should do it:
see http://npr.me.uk/remote.html
Failing that you could always do a factory reset.
Quote service system ifdelete name=HTTP group=wan
saveall
03-03-2015 10:03 AM
thanks, I'll try that out.
Message 3 of 3
(1,974 Views)
