Technicolor TG582n can't login if dsl down
Roy01
Hi.  If I try to log into the admin account on the TG582n router when dsl is down, the login isn't accepted.  Instead, I just get empty edit boxes again, and NO message saying "invalid username or password".  A look online give ma a YouTube video of the same thing happening.  When DSL is up, it works OK.  If I deliberately  drop the connection while already logged in, I can view other pages as usual.  Also, when browsing and DSL drops, I used to get the admin login screen when I clicked a link.  If I try Internet Explorer instead of FireFox, I can log in normally regardless of DSL is down or not.  Same login problem happens on two old laptops as well.  Is this a router fault, firefox fault or both?  In IE, if DSL is down and I try a website, it still doesn't bring up the login page but instead says "this page is unavailable" (or something like that).
Shep41
Re: Technicolor TG582n can't login if dsl down
This sounds like a browser issue. What versions of internet explorer and Firefox are you running ?
Roy01
FireFox 56.0.1 64-bit
IE 11.0.9600.18816
On my desktop PC, I'm running Windows 7.  On the laptops it was XP, so I rarely use them on the net these days.  They are actually netbooks, so very very slow!
notmyname
Bring your DSL link up, then get to the admin page.  From there disable @"Web browsing interception"
https://www.intelligentpos.com/uk/support/faqs/how-disable-web-browsing-interception-technicolor-rou...
That should (hopefully) fix the problem.
Roy01
Thanks, I just tried it and it worked.  Presumably then, FireFox in it's latest version is doing something that screws up the "interception", whereas IE doesn't?  I presume this means that if DSL drops out while browsing, I won't get the login page appearing as it used to?  It wasn't much use anyway - you just had to wait for it to automatically connect again.
