turn on suggestions
Technicolor TG582n and RouterStats
- Technicolor TG582n and RouterStats
15-12-2012 4:55 PM
Has anyone managed to get the TG582n to work with RouterStats? I've tried Routerstats and RouterStatsLite, both of which list the TG582n as supported, but although they both seem to log on to the router OK all speeds and SNRs are reported as zero. Is the PlusNet version incompatible with RouterStats?
Re: Technicolor TG582n and RouterStats
15-12-2012 5:00 PM
Working fine here.
jelv (a.k.a Spoon Whittler) Why I have left Plusnet (warning: long post!) Broadband: Andrews & Arnold Home::1 (FTTC 80/20) Line rental: Pulse 8 Home Line Rental (£13/month) Mobile: iD mobile (£4/month) |
15-12-2012 5:48 PM
Problem solved. Reverted to older version of RouterStats Lite and it works fine!
15-12-2012 5:58 PM
Strange, I'm running RouterStats 6.8c and it's absolutely fine.
In configuration I enabled Login and entered the admin user and password. Then on the Noise Margin and Sync Speed graphs I think I had to tick the little box aat the bottom left hand corner to say they should be plotted.
15-12-2012 10:49 PM
6.8c works for me now - must have been finger trouble.
