Technicolor TG582n and RouterStats
- Technicolor TG582n and RouterStats
15-12-2012 4:55 PM
Has anyone managed to get the TG582n to work with RouterStats? I've tried Routerstats and RouterStatsLite, both of which list the TG582n as supported, but although they both seem to log on to the router OK all speeds and SNRs are reported as zero. Is the PlusNet version incompatible with RouterStats?
Message 1 of 5
(1,408 Views)
4 REPLIES 4
Re: Technicolor TG582n and RouterStats
15-12-2012 5:00 PM
Working fine here.
Message 2 of 5
(483 Views)
15-12-2012 5:48 PM
Problem solved. Reverted to older version of RouterStats Lite and it works fine!
Message 3 of 5
(483 Views)
15-12-2012 5:58 PM
Strange, I'm running RouterStats 6.8c and it's absolutely fine.
In configuration I enabled Login and entered the admin user and password. Then on the Noise Margin and Sync Speed graphs I think I had to tick the little box aat the bottom left hand corner to say they should be plotted.
Message 4 of 5
(483 Views)
15-12-2012 10:49 PM
6.8c works for me now - must have been finger trouble.
Message 5 of 5
(483 Views)
