Technicolor TG582n - Media Server Settings
rssg
My TG582n  which arrived last week only  does not have the USB port. Is their any documentation on how to configure it as a media server and how do I connect my USB external HDD to it.
Re: Technicolor TG582n - Media Server Settings
Hi rssg,
Welcome to the community forums.
The 582n router supplied on our ADSL connections does not come with a USB port, it's only with our fibre service that the USB version is provided, so unfortunately you would not be able to connect via a USB connection.
rssg
Thanks for your reply. Is their any documentation on how to configure it as a media server?
les37b
Quote from: chrispurvey
Hi rssg,
Do I have the wrong router? I'm on fibre but mine has no usb!
@rssg
It will serve media happily, but you can't get the media to the router because there is no USB port.
@guv
Our fibre router should have the USB port on the side, the only difference in the two router are the USB port.
