Technicolor TG582n - MAC OS-x 10.7.4 does NOT support the router
- Technicolor TG582n - MAC OS-x 10.7.4 does NOT supp...
- « Previous
- 1
- 2
- Next »
Re: Technicolor TG582n - MAC OS-x 10.7.4 does NOT support the router
23-05-2012 8:28 AM
23-05-2012 8:34 AM
23-05-2012 8:46 AM
thank you for your help and advice.
I still haven't managed to get it done. i use macbook pro and i bought it less than six months ago.
I tried manually set it up it some of you explained. it did not work.
PlusComUK, I am going to contact plus net today and ask them to send me a new router. before doing that i just wanted to clarify that you don't have any problem with yours?
GUYS HELP ME I WANT TO GET IT WORK
23-05-2012 8:49 AM
if I want to connect to my router manually which one should I use afp:// or smb:// and how exactly should I set it up?
23-05-2012 8:51 AM
Quote from: yoop Hi Guys
Absolutely NO problems, I only use it as a basic router, I connect with Wi-Fi, but Ethernet works great too
My PlusNet supplied router (before March 2012)
Thomson TG585 v8 Software Release: 8.2.7.8
Works perfectly for me, new iMac 10.7.4
And older iMac 10.6.8
Wi-Fi for both ( and both at the same time, no problems )
I also have my SKY+HD box plugged into it, for Anytime+ downloads
And my Freeview HD box for "Space" etc, and Olympics downloads.
I have always found the tech guys at PN excellent in setting up and reconfiguring my router, when Network problems arise.
23-05-2012 9:01 AM
Can you "ftp" it or map a specific folder with the MAC at all, or will it not see at all?
23-05-2012 9:13 AM
AnotherOne, when i try ftp, login box pop up but even with admin username/passwd it says "This file server will not allow any additional users to log on."
Ps. ftp is ON in my router setting.
PlusComUk, does your router have USB port? have you ever tried to connect a device to it?
23-05-2012 9:28 AM
23-05-2012 9:35 AM
guy have a look at this :
[font=Verdana]http://support.apple.com/kb/HT4700?viewlocale=en_US&locale=en_US
[/font]
I don't know which one should i deactivate? "Cleartxt Passwrd", "MS2.0", "2-Way Randnum exchange", or "DHCAST128" ? what do they mean anyway?
23-05-2012 9:42 AM
Quote from: dvorak I'm pretty sure 585v8 doesn't have a usb port so wouldn't meet your requirements.
No it doesn't
23-05-2012 10:59 AM
https://discussions.apple.com/index.jspa?categoryID=1
and check out the section on Lion
- « Previous
- 1
- 2
- Next »
