Technicolor TG582n FTTC & SNTP Error
pengbo
The ntp server/settings don't appear to be working on my new router.  Getting the following in the logs
SNTP Unable to contact server: 212.159.13.50
Doesn't appear to matter what ntp server I try, tried the *.uk.pool.ntp.org ones and they don't work either.  My router was restarted 2 days ago and it now thinks it's Jan 3rd dunno what year.
It doesn't appear to be affecting it in anyway so does it matter? and or anyone discovered this before and know of a fix?
Re: Technicolor TG582n FTTC & SNTP Error
Have you tried using the IP addresses rather than the www names ?
I use the following on my TP-Link without any problems :
194.164.127.5
130.88.203.12
Fixes: 67
After a reset the router time starts off as zero in Linux terms which is equivalent to 01/01/1970 00:00 (sometimes called the epoch). 5 minutes after restart it should contact the ntp server and update to the proper time. Since that is failing the time will still be based on epoch time, so two days afterwards is 03/01/1970.
Time not updating suggests something is wrong with the internal set-up. I suggest trying a factory reset and let it set itself up again.
David
pengbo
thanks picbits and spraxyt.  It's no biggie as I think I will be changing the router soon as I need to replace the 2910VG with one that can handle the throughput and still allows VPN.
The reason I wasn't using the ip-addresses was simply because it would defeat using the ?.uk.pool.ntp.org as the 4 possible addresses are dynamically assigned from a list of something like 200 different time servers.
Anyone got any recommendations for good routers that do VPN site to site using an iPsec tunnel?
Fixes: 4
I wish you guys would speak English! It's not fair on us oldies.  Sad
pengbo
sorry tijara33.  but given a few more days I can probably add some more acronyms if you like  Cheesy
@pengbo - have you tried ntp.plus.net ? Works for me...
Stubloke
Same symptoms as pengbo, FTTC and same router.
Must be a firmware bug.
Will it be fixed in an update soon?  Mine is running 10.2.5.2
It is annoying because the logs all tell the wrong time without it.
Fixes: 6
Have you changed the dns setting in the router by any chance?
TORPC
Quote from: ejs
See: https://community.plus.net/forum/index.php/topic,113730.0.html
If the Plusnet Broadband Firewall set to "high", then ntp won't work.
See  What would cause TG582n to not connect with time server(s) (SOLVED)
Stubloke
DNS left at default.  Firewall set to off (the Plusnet member site one).
Still once per minute there is a message saying could not connect to SNTP server.
Other devices on the network in the house use NTP and work.
Fixes: 6
Can you ping 212.159.13.50  ?
I get a reply here but it a tad slow considering I'm on the same network.
Pinging 121.159.13.50 with 32 bytes of data:
Reply from 121.159.13.50: bytes=32 time=296ms TTL=48
Reply from 121.159.13.50: bytes=32 time=302ms TTL=48
Reply from 121.159.13.50: bytes=32 time=295ms TTL=48
pwatson
<Cough>  Typo on the 1st octet npr...
Fixes: 6
Thanks, that explains the ping times.  Grin Grin
Stubloke
Firewall was initially set to HIGH and I changed it to off ... but I did not disconnect and reconnect the connection on the router.  I will try that when I get home.
Other devices (webcam and android ntp client) seemed to work anyway, so I'm not sure why they work if a blocked port #"123" is to blame.
