Technicolor TG582n FTTC - Why is WiFi So Slow?
- Technicolor TG582n FTTC - Why is WiFi So Slow?
05-12-2012 1:31 PM
So to my point, how awfully slow is the WiFi? I have identified what channels neighbours are using so I have changed my Router to a channel that is not used (now set to 12).
It really takes the shine off the Fibre offering by Plusnet.
I am in the next room to the Router so it is hardly a challenging distance between me and the Router.
I realise there are many topics on this subject on this forum, but I thought I would start a new one.
If anyone has any experiences, suggestions, I would be really grateful.
Andrew
Re: Technicolor TG582n FTTC - Why is WiFi So Slow?
05-12-2012 1:55 PM
05-12-2012 2:03 PM
Just ran a Speedtest.net test and wirelessly I get 3.91 MB/s which is really poor.
Wired, using Speedtest.net, I get 49.94MB/s
So much difference as you can see.......
Andrew
07-12-2012 11:28 AM
Quote from: _Adam_Walker_ Sorry to hear you're having issues with speeds over wireless. I'm just wondering what the extent of the issue is and how speeds over wireless compare to those over Ethernet?
Adam, My fiber is 75GB via Ethanet but only 25GB via wifi
I'm working through the channels but not found one that works yet.
It seems your Technicolor TG582n routers don't support fast wifi???
VERY disappointed.
07-12-2012 5:04 PM
07-12-2012 5:23 PM
07-12-2012 9:34 PM
I had a Technicolor TG582n from my last ISP (O2) so knew what to expect with the wireless speed /signal .
It wasn't a big problem before as I was only getting 4 - 5 Mb but now I'm on 78Mb I wanted something a bit more reliable , when I opened the wireless settings in to the router on Wednesday it said
what's the point of having a 78Mb connection when the wireless is running at 6.5 Mb
Quote Actual Speed [Mbps]:6.5
It Puzzles me how something that's almost obsolete at 4 years old can outperform a current router being mass supplied.
02-07-2014 12:20 PM
02-07-2014 1:12 PM
Wile we're aware that the Technicolor TG582n isn't a premium router we do normally find that the specification will adequate for most users of the service. We're always on the look out to improve our offerings but as I'm sure you can all agree, working out a deal of this type can be a complex, time consuming and labour intensive job and would no doubt take a considerable amount of time to work out.
With wireless there is always going to be additional outside factors that will cause issues with the signal strength, this can range from other networks (as mentioned already) to wall thickness between rooms and even other forms of interference internal to the home. In these cases it can be tough to resolve the issue unless you're happy to move things around to try improving the range/speeds and even looking at adding in wireless repeaters and additional wireless access points.
Just out of interest, are these wireless tests being carried out while next to the equipment to ensure that full signal strength is acquired? In addition, what class of wireless do the devices carry that are being connected to the router to run these tests, are they b/g/n?
02-07-2014 8:05 PM
Strictly speaking, other wireless networks or interference will not affect the strength of the signal output by your router. The other forms of interference would affect the signal quality (signal to noise ratio).
The trouble with wireless is that it's complicated and most of the advice on the Internet about it is wrong. The usual advice is to download some program to draw pretty graphs so that you can choose the "best" channel, determined to be the channel with the fewest or weakest other wireless networks on. Unfortunately, the channel with the fewest / weakest other networks won't necessarily be the best one, it doesn't take into account other forms of interference, it doesn't take into account how heavily each other network is used, it doesn't take into account that there might be other wireless devices close to you, but the access point (router) of the network they are on could be further away.
Counter-intuitively, it might even be better to change your channel to be the same as a stronger nearby network. The thing is, if your router transmits a slightly weaker signal, that could mean its signal doesn't reach other nearby routers. But more powerful transmissions from other routers might reach yours. Before a router (or any other wireless device for that matter) transmits something, it first listens to check that nothing else is transmitting anything. If your router detects a transmission from another network, it would wait to avoid transmitting at the same time. If the other network can't detect the signal from your router, then it can't avoid talking over it, so could end up transmitting at the same time, causing a collision. Your router would have to try transmitting the packet again. If the other router could detect the signals from your router, then the other router would wait and avoid interrupting yours, and so there would be less of a problem.
Unfortunately downloading a special program to draw pretty graphs sounds more impressive than just trying the different channels.
20Mb/s is not a particularly bad wireless speed, probably around the maximum throughput an 11g device could achieve. There are significant extra overheads added when an 11n network operates in one of the various 11g compatibility modes, which results in slower throughput speeds. Having only 11n devices on your network won't necessarily avoid that, because the backwards compatibility is for everything operating on the same channel.
02-07-2014 9:39 PM
Quote from: ejs Having only 11n devices on your network won't necessarily avoid that, because the backwards compatibility is for everything operating on the same channel.
I was with you until that bit. Surely having only 11n devices on your network means that the router will not slow down to accommodate older standards? It would only do that if e.g. you had equipment with an 11g receiver, no? If you only have 11n then it will transmit at the faster speeds?
02-07-2014 10:31 PM
The legacy compatibility protection mechanisms are not about having everything slow down and use the lowest common protocol and speed.
An 11g device can't understand 11n transmissions. If an 11g device listened on the channel and heard 11n an transmission, it wouldn't be able to understand it, the unintelligible signal would be registered as noise. If the 11n transmission (noise to the 11g device) was strong enough, that would mean the 11g device would determine the channel is too noisy to use, and wouldn't be able to transmit anything. Alternatively, if the 11n transmission was from some distance away, so that it is fairly weak when it reaches the 11g device, the 11g device might try to transmit over what it sees as noise - unknowingly interrupting the 11n transmission. To avoid those problems, the usual solution is for the 11n device to first transmit a small packet at an 11g or older speed, to inform the older devices that it is about to transmit something, so that the older device knows it's not noise and not to interrupt it. And then the 11n device can transmit its data and an 11n speed.
At that level, it doesn't matter if devices are on the same network SSID or not, if they're all trying to use the same channel. In summary, it's about only one device being able to transmit at a time, and everything having to listen to avoid interrupting each other.
03-07-2014 10:10 AM
25-07-2014 7:33 PM
Plugged my old Netgear router in and the WiFi connection is 270Mbps and I don't get any drop outs. In my opinion I think the TG582n is cheap rubbish, I will just configure my old Netgear router with the connection settings and use that.
25-07-2014 8:02 PM
