Technicolor TG582n FTTC Username and Password
AdamD
How can i log in?
Tried admin then serial number but doesnt work?
Cheers.
1 REPLY
Fixes: 62
Re: Technicolor TG582n FTTC Username and Password
The username should be admin (lower case) and the password the serial number CP...... (all letters upper case). If those don't work you could drop the PPP session using the router web interface than try a factory reset on the router.
David
