Technicolor TG582n FTTC Static DNS Persistence
- Technicolor TG582n FTTC Static DNS Persistence
29-11-2013 8:04 PM
(Firstly,,, moved to PlusNet Fibre, from BeThere, a few months back... loving it!)
I have the stock Technicolor TG582n FTTC router and performance is good so I'm trying to stick with it.
I have a number of services within my LAN which ultimately I will share with the outside world. It is therefore important than when connected locally a device gets DNS resolution to the correct machine on the LAN and when a device connects from outside they get served a DNS entry of my static IP on the WAN side. The WAN side works fine.
For local devices I do not run my own DNS but instead am trying to configure static entries in the router (so when devices resolve via the router they get the LAN address).
e.g.
If I have mymail.mydomain.com and my server is 192.168.1.10 on the LAN and my static IP is 1.2.3.4 I have a DNS service at my domain name supplier that points to 1.2.3.4 and locally I have an entry that points to 192.168.1.10
I can add local entries using the CLI as follows...
and then...
config saveall
This works well for a while...
but after a while it goes wrong and the entries appear to have been replaced...
This is really weird. I don't have a .225 device. But .225 is in my DHCP pool. My network has some LAN devices... and a Wireless LAN and on the Wireless LAN is a Client Bridge (DDWRT) and more devices on the LAN side of the Client Bridge.
Any idea what is messing with my static DNS entries
Thanks in advance
Nivag
e.g.
dns server host
add name=mymail domain=mydomain.com addr=192.168.1.10
and then...
config saveall
{admin}[dns server host]=>list
Address Hostname TTL (s) Domain Creator
192.168.1.10 mymail 0 <local> undefined
{admin}[dns server host]=>listundefined
192.168.1.225 mymail 0 <local>
Thanks in advance
Nivag
Message 1 of 1
(6,857 Views)
