Technicolor TG582n DNS IPv6
Update
Have a network with a Windows Server 2008 R2 is the Domain Controller with the Technicolor TG582n being the internet gateway.
I have suddenly had an issue where the client network PC's cannot get network connections properly.
Have traced it to IPv6.
The ipconfig of client Windows 7 PC's show an IPv6 DNS address which matches up with the Technicolor TG582n.
I have my server not giving out IPv6 DNS via DHCP but the router is obviously doing so.
It suddenly happened a couple of days ago.
How do I turn it off.
I have turned off the router being a DNS provider so why is it now giving IPv6 DNS/DHCP?
16 REPLIES 16
Anotherone
Champion
Fixes: 21
Re: Technicolor TG582n DNS IPv6
Have a look here http://192.168.1.254/cgi/b/is/_pppoa_/dt/?be=0&l0=2&l1=2&name=Internet (login required).
Do a text copy and paste of it here in a post but delete/leave out your username & IP addresses.
IIRC I disabled my IPv6 via the 582n's CL:I. I'll have a look at my notes.
Update
Is this what you are looking for?
Internet
Connection Information
Link Status: IPv4 connected
IPv6 disconnected
Uptime: 30 days, 7:39:32
Data Transferred (Sent/Received) [GB/GB]: 8.91 / 51.78
Connection Settings
PVC Info (VPI.VCI): -
Type: PPPoA
PPP Settings
Username: *****@plusdsl.net
Password: ******************
Connection Mode: Always-On
TCP/IPv4 Settings
IPv4 State: Enabled
IPv4 Address: 80.***.90.***/32
IPv4 Default Gateway: 195.166.128.191
Primary DNS: 212.159.6.9
Secondary DNS: 212.159.6.10
TCP/IPv6 Settings
IPv6 State: Disabled
Stateless Address Autoconfiguration: Disabled
IPv6 Address: -
IPv6 Default Gateway: -
Local Interface ID: -
Remote Interface ID: -
DNS Server 1: -
Also, here is Home Network settings:
Interface - LocalNetwork
Interface Information
Interface Group: lan
TCP/IPv4 Configuration
IPv4 State: Enabled
Auto-IP Enabled: Disabled
Use DHCPv4 Server: Disabled
TCP/IPv6 Configuration
IPv6 State: Enabled
Advertising prefix: --
Use Stateless DHCPv6 Server: Disabled
IP Addresses
IPv4 Address/Mask
Type
10.0.0.138/24 Static
192.168.10.1/24 Static
192.168.10.9 Content
Sharing
IPv6 Address/Prefix-Length
Type
fe80::9e97:26ff:fe7a:6c0/64 Dynamic
DHCP Pools
DHCPv4 Pool Name
Address Range
Gateway
LAN_private 192.168.1.64 - 192.168.1.253 192.168.1.254
Stateless DHCPv6 Pool Name
LAN6_pool
So basically, as far as I can see, I have turned off IPv6 DHCP?
Router suddenly started giving IPv6 addresses to clients DHCP thus stopping Group Policy being applied from the Windows 2008 R2 server.
The server has DHCP Ipv4 scope but no scope setup for IPv6.
Just tried to re-enable IPv6 on a client PC interface and it still boots to no Group Policy. If I disable the enable the LAN interface, it then works?
Why, how, when??  Undecided
How do I stop IPv6 from the router?
Thanks again.
npr
Fixes: 9
Do you have the DHCP server enabled in the Windows Server ?
IF so then don't you need to disable the routers DHCP server.
Update
Yes, DHCP role enabled withIPv4 scope on the server.
Only DNS is the server itself.
DHCP is disabled as far as I can tell on the router which it needs to be otherwise it will conflict with the server DHCP.
Have run a few CLI commands to query the DHCP of the router and it says no DHCP. Can't remember the exact command but found a Thomson pdf with commands.
Why then is it giving out IPv6 addresses to clients?
jelv
Fixes: 10
Try disconnecting and reconnecting until you are not on a bng gateway.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Update
Ok, thanks.
Have just checked and I am on: gateway ptn-ag02
Anotherone
Champion
Fixes: 21
Have you got the right manual for your firmware version and which have you got?
Now my page above is identical except -
On the Home Network Interfaces
IPv6 State:    Enabled
whereas I have
IPv6 Address/Prefix-Length    Type
whereas I have
No IP address configured on this interface.
When I looked in my notes, I couldn't find any CLI for the above settings, so some changes may have been made in the GUI, BUT the only other differences are the LAN IP address ranges which has reminded me of something, so I'm going to look again.
I also found an old post of mine where I said "IPv6 disabled WAN side is the default"
Update
Ok, I have restarted router a few times. Same configuration.
Still showing Home Network as:
IPv6 State: Enabled
and an IPv6 address.
Must be able to turn that off somewhere?
Cheers
Update
The router firmware is: Software Release: 10.2.5.2
AndyH
Try doing what Jelv did here - http://community.plus.net/forum/index.php/topic,121285.0.html
But rather than enabled, change it to disabled:
ppp ifconfig ipv6 disabled intf Internet
Update
Thanks for finding that AndyH.
Have tried it but says 'Interface filter(s) not matched.'
Looked again and IPv6 is showing as disabled in the: Internet Services > Internet TCP/IPv6 Settings IPv6 State: Disabled
It's in the Home Network > Interfaces > LocalNetwork  that I need to turn IPv6 off I think as that's where is says: TCP/IPv6 Configuration IPv6 State: Enabled
npr
Fixes: 9
Try the following telnet commands to disable IPv6.
dhcp serverv6 config state=disabled
ip ifconfig intf=LocalNetwork ipv6=disabled
saveall
Alternatively use backup and restore. Save a backup of the routers config file and edit it with notepad making the following changes marked in red. Then use restore to save the modified config file.
[ dhcsv6.ini ]
debug traceconfig state=disabled
pool add name=LAN6_pool
pool config name=LAN6_pool state=disabled intf=LocalNetwork localdns=enabled
[ ip.ini ]
ifadd intf=LocalNetwork dest=bridge
ifadd intf=Multicast dest=ethport4
ifconfig intf=loop mtu=4096 linksensing=disabled group=local symmetric=enabled curhoplimit=64 dadtransmits=0 retranstimer=1000 acceptra=disabled autoconf=disabled
ifconfig intf=Internet mtu=1500 linksensing=enabled group=wan acceptredir=disabled rpfilter=disabled curhoplimit=64 dadtransmits=1 retranstimer=1000 acceptra=enabled autoconf=disabled
ifconfig intf=LocalNetwork mtu=1500 linksensing=disabled group=lan acceptredir=disabled rpfilter=enabled ipv4=enabled primary=enabled ipv6=disabled curhoplimit=64 dadtransmits=1 retranstimer=1000 basereachabletime=30000 gctimer=600000 acceptra=disabled autoconf=disabled
Update
Thanks npr, that's done it!  Smiley
Where did you find the CLI commands?
jelv
Fixes: 10
npr is the font of all knowledge for the TG582: http://npr.me.uk/
