Technicolor TG582n - Can't uncheck the 'Allowed on WLAN'
- Re: Technicolor TG582n - Can't uncheck the 'Allowe...
23-06-2013 9:07 AM
Re: Technicolor TG582n - Can't uncheck the 'Allowed on WLAN'
23-06-2013 9:25 AM
I think the software release on new router is different 8.C.M.0 to old router, but can't checked as posted old faulty router back yesterday,.
23-06-2013 12:29 PM
Also, why my router is connecting on WLAN at 65mbps and not 130 as it was when the connection was set up.
Any help on these issues appreciated.
Craig
24-06-2013 9:56 AM
Thanks for bringing this to our attention, we've just tested this ourselves and we saw the same issue.
We're going to raise this with Technicolor, I've raised problem 75744 for tracking purposes.
Adam
24-06-2013 11:54 AM
24-06-2013 3:52 PM
This is how to do it with cli:
http://npr.me.uk/telnet.html#macaccess
15-08-2013 5:46 PM
I seem to be having the same problem.
19-08-2013 9:13 AM
Quote Sorry to bump up this thread but has the issue been resolved ?
No worries and I'm afraid not. I'll chase that up.
Adam
UPDATE: This still hasn't been resolved I'm afraid, I'll give the relevant people a nudge although this looks like an issue with our hardware supplier. In the meantime you should be able to resolve this by using a CLI command as per some of the previous replies to this thread.
27-10-2013 10:31 PM
15-11-2013 11:52 AM
but any more developments on this, still using the Technicolor TG582n router but STILL not able to check and uncheck Allowed on WLAN.
Any help or information on sorting this is greatly appreciated
regards
15-11-2013 12:45 PM
Quote from: npr This is how to do it with cli:
To get what you think is a 'proper' fix (ability to change via the web interface) will require the development, testing, distribution, download of a new firmware which you might then have to flash your router with. Though the CLI might seem a little daunting at first, it is a heck of a lot simpler than the route to a 'proper' fix.
16-09-2014 2:12 PM
16-09-2014 2:20 PM
wireless macacl add ssid_id=0 radio_id=0 hwaddr=00:xx:xx:xx:xx:xx permission=allow
16-09-2014 7:36 PM
Quote from: _Adam_Walker_
Adam
Has this ever been resolved ?
17-09-2014 2:56 PM
Sorry an update was never posted on here!
I've chased this up with our Products team and they've confirmed the following:
The Allowed on WLAN tick box is actually redundant and doesn't do anything, this is why it's unresponsive. The ability to dis-allow a device on the WLAN is done via a drop-down box that is only present when MAC address filtering is enabled. This is done by changing "Allow New Devices:" under the Wireless configuration menu to "New Devices Allowed (via Registration). The drop down box will then appear and you can select Yes or No for allowed.
Hope this helps!
