Technicolor Router and Synology NAS
GeraldtheGorill
For no know reason my router has stopped connecting to my NAS, it can see it but says it is unavailable? I should add that I can connect to the NAS via wifi on the same router?Huh
Re: Technicolor Router and Synology NAS
Have you tried rebooting your router and NAS?
The NAS is connected wired or wirelessly? If wirelessly, have you tried unjoining/rejoining it to your network?
GeraldtheGorill
I have restarted everything but I keep coming back to it being a router hardware issue as I can connect to the NAS via wifi and the NAS is connected by cable to the router, yet the router can see the NAS on the network says it is connected but has a cross through it and the PC which is connected to the same router does not see the NAS at all
