Technicolor 582n
rookey
Technicolor 582n
Is this router just a wireless N or is it mix as nothing I can see in settings.
David_W
Re: Technicolor 582n
It's backwards compatible with a/b/g, at least I think it does a (the oldest standard)
Fixes: 6
It's a wireless b/g/n
By default wireless n speed is 130 mbps
Wireless n can be disabled via telnet.
rookey
This something I need be sure on. As a wireless speaker system we about to buy wont work on wireless N
rookey
Can't the router beset to accept them all is it set as default?
rookey
I don't want disable wireless n I want it be able accept g and n
RPMozley
Fixes: 5
The default is multi-mode so will accept g or b clients, as well as n.
That's RPM to you!!
rookey
But there no where in setting for this be seen is it duel band too ?
rookey
Just had a look again just and notice that it now says it accept all 3 mode but that wasnt there lastnight.  Although there is no where in the settings to be able to change it anyway which is strange...
It also says it connected at at 78MBPS lastnight that was at 130 and that is when I could not see if it was on wireless N or everything.
Something strange...
apjashley1
Nope, single band only (2.4ghz)
rookey
Also can I just this router just as a Modem and have it plugged into a Airport Express and use the Airport as Wifi point if so how this done please.  Just incase just gathering all information together before I do things.
But I rather not have to do this.. I want to be confidence that the Router I have now as the Heading will do it all for me.  But why is there no such setting on setting the B G N in the interface as i was able to do this on the Old Router I had with plus net but not this new one.
rookey
Can a Member of plusNet team look into this please?
apjashley1
Quote from: rookey
Here you go buddy http://community.plus.net/forum/index.php/topic,111711.msg959521.html#msg959521
