Technicolor 582n router - BT Openreach didn't fit a Fibre modem
tw199y2011
Hi
I am awaiting for this router to turn up due to a technical error on PN side of things.
I upgraded to fibre this morning and the BT engineer has been out and fitted my new faceplate.  The website states he will install a new fibre modem as well but he never.  Also can i use my existing ADSL router why waiting for this one to turn up?  I work in a computer shop and our network engineer said it should but i will only get the normal speeds not fibre speeds.  Just that ATM this has no internet connection either.
jim:green Title changed to make the problem more obvious mod:end
Fixes: 58
Re: Technicolor 582n router
He should have installed a fibre modem and you won't have ADSL available once you have been connected to fibre
Fixes: 12
Re: Technicolor 582n router - BT Openreach didn't fit a Fibre modem
Quote from: tw199y2011
think the network engineer needs to refresh his knowledge or stop making things up Cheesy
MattyC
Champion
Fixes: 46
He certainly should have installed the fibre modem.
I will get someone to get in touch with you shortly.
stephenw10
Had my FTTC connected on Wednesday this week and the engineer who turned up said there was a note; 'no modem needed' on his instructions. Luckily he was a good guy who asked me if that was true and I strongly suggested I needed a modem!  Roll eyes
Steve
tw199y2011
Quote from: MattyC
Thanks for reply.  I thought that should have been the case, as it mentioned on your support pages.
Have just spoken to someone in customer support and explained what happened he is putting it through to provisioning.
Just waiting on a new date for install.  No internet access till then Sad
MattyC
Champion
Fixes: 46
Thanks for speaking with me this afternoon tw199y2011.
As agreed, your router is on it's way. Openreach will have you a modem by Tuesday morning.
Have a nice weekend.
