Technical Support request: IDS DOS Parser : UDP Flood Technicolor router TG582n
- Technical Support request: IDS DOS Parser : UDP Fl...
15-04-2015 8:52 PM
I am trying to make a video call but the router is seeing the video traffic as a DOS attack then restarting the router, please see logs below: is there a way to switch off or bypass the IDS in the router? Plusnet Chat support were not helpful, they just said have you done a speed test and to post my query here:
IDS dos parser : udp flood (1 of 1)
KERNEL Warm restart
Product Name:TG582n
Software Release:8.4.4.J
Software Variant:BV
Boot Loader Version:1.0.5
Any advise would we welcome
Bav
KERNEL Warm restart
Product Name:TG582n
Software Variant:BV
Bav
Message 1 of 3
(1,791 Views)
2 REPLIES 2
Re: Technical Support request: IDS DOS Parser : UDP Flood Technicolor router TG582n
15-04-2015 9:16 PM
I am just an unqualified onlooker but your Software version looks to be out of date.
Message 2 of 3
(1,218 Views)
15-04-2015 10:44 PM
You could disable IDS.
Need to use telnet to do this, you'll find the commands here:
http://npr.me.uk/telnet.html#ids
Message 3 of 3
(1,218 Views)
