Target SNR
- Target SNR
Target SNR
03-01-2016 9:58 PM
The target SNR for my line appears to have increased from 6 to 9. Can someone from plusnet please reset it back to 6?
Message 1 of 3
(664 Views)
2 REPLIES 2
Re: Target SNR
03-01-2016 11:49 PM
Hi mcilroyclan1,
A warm welcome to the forums.
There is little point requesting a snrm reset without finding out why the dlm has raised it from the normal value. There is a high probability that it will just revert to 9dB.
Is there any noise in the phone line? Dial 17070 option 2 using a corded phone plugged into the master socket.
Take a look at the speed issues thread and post the requested stats.
@CRT,
Can you please post a VR plot and error history?
@CRT,
Message 2 of 3
(306 Views)
Re: Target SNR
04-01-2016 1:28 PM
Hi all, the line is showing as perfectly stable and without errors so I'm happy to perform an SNR reset.
@mcilroyclan1
Please keep an eye on things over the next 24 hours and do post back if you encounter any issues.
@mcilroyclan1
Message 3 of 3
(306 Views)
