Target SNR
- Target SNR
- « Previous
- Next »
Re: Target SNR
29-09-2013 6:04 PM
There u go. Here is screenshot.
Message 31 of 37
(484 Views)
Re: Target SNR
29-09-2013 6:14 PM
That's much, much better. There are still severe error seconds (Severe ES) but I would expect this on an interleave depth of 1. The CRCs are fine as are the error seconds. As far as I am concerned, this is case closed.
Message 32 of 37
(484 Views)
Re: Target SNR
29-09-2013 6:16 PM
Yep, I leave it on for 10 days and see what the DLM decided to do with my line. Sound like DLM doesn't like below 3.0dB SNR.
What does Interleave Depth 1 mean? and what is Reed Solomon is? Large number on the upstream.
Message 33 of 37
(484 Views)
Re: Target SNR
30-09-2013 1:14 PM
The depth of interleaving is applied in different levels of aggression, for ADSL it is: 1(lowest),2, 4, 6 & 8(highest).
Reed Solomon isn't something that you need to be worried about, you can read more on this here.
Message 34 of 37
(484 Views)
Re: Target SNR
30-09-2013 1:53 PM
It now nearly 2 days and the errors isn't that bad compare to 24 hours ago isn't it?
Message 35 of 37
(484 Views)
Re: Target SNR
30-09-2013 5:07 PM
It does look better, it would be best to leave your connection stable and continue to monitor this.
Message 36 of 37
(484 Views)
Re: Target SNR
01-10-2013 3:24 PM
Thanks Chris. It now stable for 72 hours (3 days now)
The line probably drop out connection anytime now because I can see the plusnet current line speed at 15.4Mb from 17Mb. (The last change of my current line speed at 17Mb was as of 18th September) blimey took two weeks to change itself.
Message 37 of 37
(484 Views)
- « Previous
- Next »
