Target SNR Tweak
- Re: Target SNR Tweak
Target SNR Tweak
27-02-2013 1:52 PM
Please could I have my target SNR manually set to 3 both ways?
Line is rock solid at the moment (apart from a manual reset just now and one overnight).
I reckon it can handle a bit more speed.
Message 1 of 2
(557 Views)
1 REPLY 1
27-02-2013 3:30 PM
Hi apjashley1,
Unfortunately we can't set it to 3dB on your upstream, looking further into this, the lowest is 6dB on the upstream and 3dB on your downstream. It would only be possible for you to do this if you had a modem/router that would allow you to tweak your upstream dB.
Message 2 of 2
(302 Views)
