Target SNR Change Please
- Target SNR Change Please
- « Previous
- Next »
Re: Target SNR Change Please
05-07-2015 1:29 AM
I think I'm going to move this connection away from Plusnet aswell as Customer Service is starting too suck...
12-07-2015 7:14 PM
Looks like it's been a week since your last post and still no response..
12-07-2015 11:42 PM
14-07-2015 2:30 PM
Quote Downstream SNR: 12db Upstream SNR: 9db Interleaving off on both (as silly as that sounds)
14-07-2015 2:33 PM
The profile is still at WBC 160K - 24M Medium delay (INP 1) 3dB Downstream, UC Medium delay (INP 2) 6dB Upstream (ADSL2+)
Do you want any changes making or is the stability good at the moment from your point of view?
14-07-2015 9:58 PM
Excuse me for being a bit direct but took a while
If you could, I would like both Up&down SNR set to 9bd and all interleaving removed..
Interleaving has only made performance worse,
I'm almost sure there is a fault with line somewhere at the exchange, just liek there was when it was first provisioned but honestly, I CBA to go down the route of even trying to get this done and will be having the line ceased in the next month or 2..
Please update this thread once you have pushed through new configs..
Cheers
15-07-2015 11:33 AM
15-07-2015 11:51 AM
What we'd need to do is place a modify order (1 day) to turn interleaving to auto or off, and once that's completed do the 9db changes.
Does that sound ok?
15-07-2015 11:59 AM
15-07-2015 12:25 PM
15-07-2015 1:44 PM
16-07-2015 9:01 AM
Quote from: Chris OK, that order's in place. Need to do the 9db's tomorrow.
Looks like were ready for the SNR change!
16-07-2015 11:44 AM
Should happen within the next 15 minutes or so.
16-07-2015 12:44 PM
Quote Statistics -- xDSL
Mode: ADSL_G.dmt
Traffic Type: ATM
Status: Up
Link Power State: L0
Downstream Upstream
Line Coding(Trellis): On On
SNR Margin (0.1 dB): 91 90
Attenuation (0.1 dB): 600 315
Output Power (0.1 dBm): 179 125
Attainable Rate (Kbps): 3,392 868
Path 0 Path 1
Downstream Upstream Downstream Upstream
Rate (Kbps): 3,264 768 0 0
K (number of bytes in DMT frame): 103 25 0 0
R (number of check bytes in RS code word): 0 0 0 0
S (RS code word size in DMT frame): 0.50 1.00 0.0 0.0
D (interleaver depth): 1 1 0 0
Delay (msec): 0.13 0.25 0.0 0.0
INP (DMT symbol): 0.00 0.00 0.0 0.0
Super Frames: 1,058,282 1,058,282 0 0
Super Frame Errors: 5,405 702 0 0
RS Words: 0 0 0 0
RS Correctable Errors: 0 1 0 0
RS Uncorrectable Errors: 0 0 0 0
HEC Errors: 2,257 688 0 0
OCD Errors: 3 0 0 0
LCD Errors: 3 0 0 0
Total Cells: 27,425,505 0 0 0
Data Cells: 113,870 0 0 0
Bit Errors: 0 0 0 0
Total ES: 1,569 0
Total SES: 25 0
Total UAS: 30 30
16-07-2015 12:46 PM
- « Previous
- Next »
