Talk Talk Router HG633
welshguy2016
Any idea if Talk Talk HG633 routers work on Plusnet?
3 REPLIES 3
Anoush
Aspiring Hero
Fixes: 139
Re: Talk Talk Router HG633
Hello there. From searching the router on Google, it appears to be locked to TalkTalk, I'm afraid. Sad
This is my personal Community Forum account to help out around these parts while I'm at home. If I'm posting from the 1st March 2020, this means I'm off-duty with no access to internal systems.
colleen1985
https://community.plus.net/t5/My-Router/Talk-Talk-Router-HG633-configuration-setting-for-plusnet-mos...
already solved please see attached pictures and check out my post Smiley
Did it today and joined to share
davelynne5
Hi thank you very much
as just joined plusnet moved over from talktalk.
worked a treat. with super router HG635 ver G.1.01
there another advantage to using the talktalk router as you can edit DNS the google servers are quite fast and free and plus net provide DNS address that avoid/circumvent
Plusnet Protect
I use openVPN and subscbribe to FrootVPN
google free DNS work well and fast just tick static DNA on the bottom of the same page and enter address and save
plusnet primary DNS 212.159.13.49
Plusnet secondary DNS 212.159.13.50
google primary DNS 8.8.8.8
google secondary DNS 8.8.4.4
the google DNS solve a lot of lag on browsers.
It also worth reading up ON DNS there plenty of articles
Thanks again
