Tablet Connection
- Tablet Connection
Tablet Connection
14-11-2011 3:30 PM
I have bought an Android tablet which connects perfectly well using BT but I am now at home and trying to connect via Plusnet and it continually scans and doesn't pickup my Plusnet wifi, (my laptop connects fine) The supplier says it must be a router problem but Plusnet tech support said they don't support the router. As I am not remotely technical can anyone help please.
Message 1 of 4
(726 Views)
3 REPLIES 3
Re: Tablet Connection
14-11-2011 3:32 PM
which router and how is the wifi security set up
Message 2 of 4
(354 Views)
15-11-2011 10:23 AM
Thank you for replying. The problem has been solved. When connecting it asked for the 'Password' which I assumed was the Router Password, (which I entered on the BT line) but what they actually wanted was the Wireless Key, as soon as I entered that it worked. Simple when you know how. It's just a shame that Plusnet Tech support didn't tell me that when I first rang instead of just telling me the don't support the router!! I eventually got the answer 6 hours later from the on-line support (as well as a suggestion from my brother)
Message 3 of 4
(354 Views)
15-11-2011 2:30 PM
Hi Mallard17,
Glad to hear you got it sorted, sorry about the initial answer you got there. I'm afraid we can't really offer support on routers that we don't supply but for such a general question we should have been able to answer.
Please do pop back here and drop a post in if there's anything else we can do for you.
Message 4 of 4
(354 Views)
