TPLink WR1043ND
- Re: TPLink WR1043ND
TPLink WR1043ND
21-01-2013 10:38 PM
I have plusnet unlimited fttc (80/20) getting 63mbps/17mbs on supplied router:happy days:)
However, I wanted to use my tplink wr1043ND with current firmware as it has gige ports for internal LAN
I managed to set up pppoe so it connects but performance is really poor:(
Any hints on whether this should work at the same speeds as the supplied technicolour router?
thx
Re: TPLink WR1043ND
22-01-2013 10:17 AM
I "only" have ADSL at 3Mbps but used that layout with a Thomson 585 (connected to a single port ADSL modem/router) as a "setup" option to initialise my WR1043ND before mothballing the 585. It should autoconfigure for the correct WAN connection type.
Phil
Re: TPLink WR1043ND
22-01-2013 10:36 AM
With the supplied Technicolor router, I got 71Mb download speeds
With the DGFV338 I only managed to get 40Mb download speeds
With TP-Link TL-WR841ND I get 73Mb download speeds
All very strange and needless to say I've stayed with the TP-Link but it does show there can be quite a variance between Routers.
How poor is your "poor" performance ?
Re: TPLink WR1043ND
26-01-2013 12:16 PM
My results are
supplied TEchnicolour router
Wired: 57mbps u/l and 17mbs d/l
WLAN 24mbps u/l and 16mbs d/l
TPLINK wR1043ND
WLAN between 1 and 8 mbps erratic u/l and 10mbs d/l
Could you do me a big favour and try out the TPLink WLAN speedtest for me? This is really doing my head in :-\PPP
I think it is a TPLink issue between PPPoE and WLAN.
Also, completely unrelated, when I swap over the routers they take about 5/6 mins to connect; is this normal?
Quote from: picbits I had a play with the routers I had knocking about when my FTTC was installed a few days ago. I really wanted to use my Netgear DGFV338 as it was set up for all the appropriate port forwarding / firewalling etc.
Re: TPLink WR1043ND
26-01-2013 12:20 PM
Quote from: PeeGee Can't answer your question, but what happens if you connect the WR1043ND WAN port to the Technicolour? That may provide some clues.
Phil
Thanks for suggestion. I'm sure I tried that, I've forgotten what I have tried now but will give it a try because as it will not require PPoE it will verify whether PPPoE is the issue or not.
Re: TPLink WR1043ND
26-01-2013 12:21 PM
Re: TPLink WR1043ND
26-01-2013 12:25 PM
Re: TPLink WR1043ND
26-01-2013 12:29 PM
Re: TPLink WR1043ND
26-01-2013 12:32 PM
that is more or less what I get with my Plusnet router, 54g limitations I guess.
What I need is someone with a WR1043ND to test that
Re: TPLink WR1043ND
26-01-2013 12:36 PM
The wifes Dell laptop (newer than my 4 year old Dell laptop) has a wireless N built in and she initially could only speedtest at 10/10Mb but after half an hour of use she got similar speeds to me.
She's just tested again and got this :
Re: TPLink WR1043ND
26-01-2013 12:43 PM
It isn't my laptop as problem persists with different devices.(wifesand daughters modern HP and Dell laptops and my oldAcer and Samsung S2)
Yes, I've tried different channels and most of the other WLAN settings! I really think it is a bug but I will try the option of TPLink WAN port to LAN port of Plusnet to see what I get,.
I am sure that was the first thing I tried though!
