TP-Link W8980 Router Assistance please...
- Re: TP-Link W8980 Router Assistance please...
14-02-2014 6:58 PM
I set up a TP-Link W8980 today on an ADSL2+ connection and I have what appears to be two WAN interfaces configured...see attached screen shot.
Not being familiar with TP-Link routers is this normal or should the 'Bridge' interface not be there?
The router is working fine....and is showing the 582n it's replaced how it should be done.
Any help appreciated.
Message 1 of 8
(2,241 Views)
7 REPLIES 7
Re: TP-Link Query
14-02-2014 7:04 PM
I'd say that was normal, but I'm not a TP-Link expert either I'm afraid.
Message 2 of 8
(677 Views)
14-02-2014 7:54 PM
I have that router that looks normal the other wan interface is for when its used for fibre, hope that helps
Message 3 of 8
(677 Views)
14-02-2014 7:57 PM
Thanks guys
Message 4 of 8
(677 Views)
15-02-2014 11:40 AM
I was just wondering if the bridge interface is not required and could be deleted.
It says it's connected but connected to what as I don't have fibre and is it using resources which could best be used elsewhere in the router.
Or is it the internal bridge between the WAN and the LAN.
Edit: Just found this on Portforward site which seems to confirm that everything is fine.
Message 5 of 8
(677 Views)
16-02-2014 1:30 PM
Does anyone have an idea how to get a decent set of stats out of this router.
The attached is the best I can find but no FEC, HEC or ES stuff.
Message 6 of 8
(677 Views)
16-02-2014 6:50 PM
It might be possible to do something clever with JavaScript, based on the source of the status.htm page
I don't have this router and the TP-Link online emulator doesn't have the DSL connected, but the basic idea is, while on the DSL status page, to open Tools -> Web Developer -> Web Console and paste the code quoted above into the input line at the bottom of the console, but all on one line, and replacing dslStk with something that works, maybe "pppoa_0_38_0_d":
And then clicking on the object array returned - with the online emulator, it returns an empty array, either because the code I'm guessing doesn't work, or because the DSL interface isn't connected in the emulator.
Quote from: source var wanDslInfSta =$.act(ACT_GL, WAN_DSL_INTF_STATS_TOTAL, dslStk, null,
["ATUCCRCErrors", "CRCErrors", "ATUCFECErrors", "FECErrors",
"SeverelyErroredSecs", "X_TPLINK_US_SeverelyErroredSecs",
"erroredSecs", "X_TPLINK_US_ErroredSecs"]);
$.act(ACT_GL, WAN_DSL_INTF_STATS_TOTAL, "pppoa_0_38_0_d", null, ["ATUCCRCErrors", "CRCErrors", "ATUCFECErrors", "FECErrors", "SeverelyErroredSecs", "X_TPLINK_US_SeverelyErroredSecs", "erroredSecs", "X_TPLINK_US_ErroredSecs"]);
Message 7 of 8
(677 Views)
17-02-2014 9:46 AM
Thanks ejs.
I'm sure that would be a good solution if I understood it thoroughly but sadly I don't.
I'd probably end up bricking it
Message 8 of 8
(677 Views)
