TP-Link TL-WR1043ND
bradw
TP-Link TL-WR1043ND
I've been trying to set-up this TP-Link router to replace the Technicolor TG582n (FTTC)
It has DD-WRT installed, I put in what I believe to be the correct settings and hooked it up to the OR modem - restarted both but it doesn't connect.
Any one here have an idea as to what I'm doing wrong?
Thanks!
8 REPLIES 8
Fixes: 395
Re: TP-Link TL-WR1043ND
I can't see anything wrong with that. You may need to leave the router for up to 8 minutes before it connects, due to an issue with long pppoe timeouts ( see here http://community.plus.net/forum/index.php/topic,114808.0.html ).
If it still doesn't connect then try using the pppoe debugging facilities http://www.dd-wrt.com/wiki/index.php/Debugging_PPPOE_Problems
rogeryeung88
Yep, it will connect eventually. Usually takes around 4-7 mins.
bradw
Thanks, didn't know I'd have to wait that long.
Am I right in saying you don't have to do the "MAC Address Clone" with plusnet?
Also under "Network Setup" I'm assuming you leave gateway blank?
bradw
It connected after leaving it for ~10 mins. Seems stable so far... Cool
bradw
Not sure If I'm just unlucky, but I've already given up on it as it disconnected ~6 times in minutes for seemingly no reason. Anyone else have luck with this router and/or DD-WRT?
rogeryeung88
Its because you checked keep alive 30 sec. You need to check connect automatically or something along those lines. Can't remember which as I use OpenWrt.
bradw
As the alternative to that is "connect on demand" I'm not really sure what to do. It was my understanding that "keep alive" never dropped the connection if idle, but I guess I'll have to look into that more.
chrispurvey
How is your connection now? It doesn't seem that you've been having any drops since.
