TP-Link TD-W9980
- Re: TP-Link TD-W9980
TP-Link TD-W9980
11-05-2015 6:37 PM
I am considering buying a TP-Link TD-W9980 modem router to replace the Plusnet Sagem 2704N which is useless at port forwarding.
Has anyone got any experience with this TP-Link device?
Also has it got slots on the back enabling it to be wall mounted?
Thanks,
Geoff
Thanks,
Geoff
Message 1 of 9
(2,103 Views)
8 REPLIES 8
11-05-2015 6:54 PM
It can be wall mounted, yes.
I haven't tried port forwarding on it, though.
Message 2 of 9
(1,011 Views)
11-05-2015 8:18 PM
Thanks Jaggies, they don't appear to tell you useful things like that in the spec.
I assume you own one? If so, have you had any problems with it?
Message 3 of 9
(1,011 Views)
12-05-2015 10:50 AM
I stopped using it when the G.INP issue raised its head, as the firmware didn't support it at the time. If you're planning on using it for ADSL rather than VDSL that should not be an issue.
On the whole I was pleased with the performance.
Message 4 of 9
(1,011 Views)
12-05-2015 11:20 AM
I've got one on fibre (the new beta f/w fixed the G.INP issue).
Port forwarding is simple to setup, just make sure it is enabled when setup as there is an option to disable it as well.
Message 5 of 9
(1,011 Views)
14-05-2015 5:24 PM
Thanks for your input
Message 6 of 9
(1,011 Views)
14-05-2015 8:55 PM
Some TP-Links do not have the ability to drop the PPP Internet session. I have no idea if that applies this this one.
If you visit their website you can download a manual. They also have an emulator on the site you could play with.
I've noted some users say their support is poor.
Message 7 of 9
(1,011 Views)
15-05-2015 9:45 AM
This one does, you can drop the ppp keeping the vdsl up.
Message 8 of 9
(1,011 Views)
15-05-2015 5:46 PM
Thanks McB, good to know.
Message 9 of 9
(1,011 Views)
