TP-Link Router wireless problem
- TP-Link Router wireless problem
03-03-2014 9:42 PM
Anything that might help it. Should I using a specific wifi channel.
Re: TP-Link Router wireless problem
03-03-2014 9:55 PM
TCP Optimizer is useful too for altering your wireless card settings to the best performance
04-03-2014 10:55 AM
11-03-2014 9:01 PM
I did use the same Ethernet cable that I had connected to the Plusnet Fibre router. Should I change to the one in the TP-Link router box?
12-03-2014 1:47 PM
Downstream Speed 67.5 Mbps
Upstream Speed 17.2 Mbps
Profile: 37M-74M Downstream, Interleaving Off - 10M-19M Upstream, Interleaving Off
So everything from that side of things looks fine.
Your Speed Profile set on our systems looks to be correct. It might be worth trying a direct connection into your Modem though? http://community.plus.net/library/broadband/fibre-help-how-to-set-up-a-pppoe-dialler-in-vistawindows...
12-03-2014 2:00 PM
12-03-2014 2:02 PM
12-03-2014 2:05 PM
12-03-2014 2:09 PM
12-03-2014 2:19 PM
12-03-2014 2:26 PM
12-03-2014 6:51 PM
Plugged in the old Plusnet fibre router, and everything seems to be working fine again.
12-03-2014 11:04 PM
Ex-Broadband Service Manager
